Jon FLA »
https://forums.nicoclub.com/jon-fla-u140051.html
Wed Nov 17, 2010 8:45 pm
A few months ago I swapped my convertible 240 with a built ka and made it manual. It recently started ticking and the nearest shop said it would be 2500 bucks to rebuild the motor. Now Im contemplating swapping in a sr20 because it is the easiest swap. The only problem I can think of that I may run into is the parking switch that I already bypassed and the top working properly. I would assume the parking switch that you had to loop and the green box would be taken out of the equation because i would use the sr20 harness and ecu. but how would i get the top to work? is it the same colors as for the ka harness? any input would be great..
Biggie!! HiJack!! i need yalls help and input..
Im looking to do the swap in december..
