sr20 swap
luis741953
Car: 1995 nissan 240sx se
wazup guys?
i getting an sr20 and ill have some guys install it for meany tips or advices?
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Be patient. Very patient.
Bwana
Car: Denali
Read through all of these FAQ's. Pretty much everything you could need to know is in there somewhere!
E7-S14
Car: ess 14 foo!
heres a tip... 1--Drop sr in2--Drive/Enjoi3---
this little botton will become your best friend.. and you might wanna check out the sr engine forum.
notslow
Car: Nissan Sileighty
Budget extra. Brainstorm a parts list before you do anything. What ever you come up with, add AT LEAST $750 on top of that price. Make sure the wiring harness if full. Dont forget you will most likely need to relocate the battery. Have your mounts examined. If it is an older 240 (89-91ish) there is a pretty good chance you will need new ones. What all do you have done to the car? If it is bone stock you are gonna need lots of mods. Make sure that when you get the engine you have it check out again. Determine if things like the clutch are still usable. (I was lucky to find an Exedy clutch on mine, got me a nice little back-up now).
More suggestions: be patient, have fun doin it, dont compromise!
adrianfromthecastle
Car: 1992 Nissan 240sx
try the quizno's bbq beef brisket. it's an sr owner's recommendation
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
adrians_s13 wrote:try the quizno's bbq beef brisket. it's an sr owner's recommendation
word, listen to this man, he knows. as an added bonus, quiznos also miraculously fixes cars when a sandwich is placed in the passenger seat......sometimes.
newfengshui
it's true, i had a subway sandwhich in my car the day i got hit by a semi.
god damn subway.
nani
Car: 89-240sx
luis741953 wrote:wazup guys?
dont let "some guys" do your job man...
white90esex
Car: 90 240sx
90 Q45
12 Titan Pro4x
06 xB
yeah swap it urself or at least attempt to. Most of it is plug and play. Its not all that much work unless there will be some sort of custom fabrication being done (im guessing there isnt).
DO it urself and u will feel alot better about ur hard work and effort. Also if something goes wrong u will be more likely to pin point the problem instead of towing it back to "some guys" and going "idk whats wronge."
Then they charge u another few hundred dollars. Alot better to just do it for urself.
If you need tips on what needs to be done ill be glad to help u. If you go to Heavythrolle.com they have an online guide that basically shows u what needs to be done step by step. They are very helpfull too.
If you havnt actually bought ur motor yet they are a good source and very helpfull.
climaxsr20
Car: 1998 Silvia RedTop
you should still research everything on the sr even though your not gonna install it. best to know your info. i would not want an sr member to look like a dumb ***, to have an sr and not know his car.
