maxima278 wrote:I just bought a blacktop SR20 to put in my S14 about 2 weeks ago that was missing a few hoses. I found most of them, just need to know about the one that comes off the turbo outlet (looks like aftermarket ones don't have this piece) and the third smaller hole on the intercooler. Pics would be great if possible.
The turbo outlet has a metal hose comes up out of it? Ok the only thing connected to the outlet on the turbo should be an extension with an o2 sensor in it. There will be another metal pipe from it that, it's the AIV, you'll need a plug for it.
On the intake side of the turbo- you've got the hose from the valve cover, a vac line, and the bov recirculation on the rubber part that hooks up to the front of the turbo. On the air outlet of the intake side of the turbo, you've got a hotpipe that should have a vac line for the wastegate actuator unless you're using the stock setup with the vac line at the smic.
