sr20 swap for my 240 neeed help!!!
fenerbahce
Car: nissan 240sx
ok i am a noob and i will admit to it because i just got this car and i do not know much about it but i want to do a s13 sr20det swap reallly soon and i dont know if these are all the parts i need here is what i got if there is any other parts can anyone please tell me THANKS :D
-the engine -spec stage 2 kit sprung - 380tq... clutch kit-Throttle Body-Transmission 5Spd RWD (with Clutch Assembled to the engine)-Wiring Harness-All required Cables-ECU-Exhaust Manifold-Alternator-Starter-Power Steering Pump-Power Steering High pressure Line-Wastegate solenoid Controller-Wastegate actuator-A/C-Fuel Rail-Injectors-Canistor-Turbo-NGK V-power heat range 6 ... spark plugs-megan racing stainless steel with flex section... downpipe-greddy type M FMIC kit with pipping... fron mount intercooler-blow off valve-permacool single 2750 cfm.... electric fan-intake filter kit- gauge package-boost controller
thanks for the help!
180fan
Car: 89 fastback
make sure your cas ain't busted and that you're getting a mafs. if you're using an older s13, you'll need the power steering lines and reservoir as well. you'll need the ac lines made/rigged to mate up to the sr's. where's the transmission on the list? Or the knock sensor?
K.I.S.S.Get a complete engine set, make sure you get compression numbers, have the cas tested, look for blown oil seals and play in the turbo with an uncut wiring harness.
hpmachine
Car: '05 EVO8 + '95 240sx
Get in touch with JDM Exchange in Philly. They know their stuff.
otterman
-the engine -Throttle Body-Transmission 5Spd RWD -Wiring Harness-ECU-Exhaust Manifold-Alternator-Starter-Wastegate actuator-Fuel Rail-Injectors-Turbo
That should all come with the engine when you buy it.
adrianfromthecastle
Car: 1992 Nissan 240sx
your gonna either need to get a different downpipe, or modify the megan one, cuz the ground clearance sucks balls, and eventually you'll get a hole right were the flex piece is at. what you can do is if you want to modify it, take it to a muffler shop and have them chop off like an inch and a half of the pipe that goes down.
fenerbahce
Car: nissan 240sx
thanks everyone
