180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sat Jan 24, 2004 11:48 am
The links might not immediately line up with the colored links. With the chain I just pulled, the links were colored black. The new revision to the design is colored silver. It may take a few cranks to get the links to match up with the punchmarks on the cam sprockets. Then you can line up the CAS as they've got on the website.
Check the pressure via the fuel pressure regulator. If there's fuel pressure there, chances are your injectors will be getting fuel. The spark, check the igniter, coil packs, and the CAS.
