Hoffman5982 »
https://forums.nicoclub.com/hoffman5982-u77367.html
Thu Sep 15, 2011 10:57 pm
Check to see that your injectors aren't leaking. Pull the rail with injectors intact, turn the key to let the pump prime, and if any gas leaks out check your o-rings and pintle caps. As Omega said, check the fuel pressure. If that's fine, pull all of your spark plugs. If only one or two are fouled, the injectors on those cylinders are most likely leaking and/or stuck open.
