The OEM Crank would be good for about 1000HP, more the enough.
About the sleeves, i am just at the same dillema. I just rebuilt my motor with Dartons, and they Leak coolant into the oil pan.
Sleeve instalation is like picking a number to win the lottery.They can Sink, or Leak, or actualy do the job.
From my research i have decided that unless you plan to go for more than 87mm, or have a damage block you are trying to save - THERE IS NO NEED FOR THEM.
The OEM sleeves have a 5 mm wall thikness - the same as DARTONS.They will never sink, and never leak coolant.
The cance of getting a doggy fitting, and ruining the block, is not worth it. Not to mention building the whole motor, and then having to tear it up again.
I am now looking for a new block, to rebuild without sleeves. I made a mistake.
Most people that run about 400-500 with STD bore, do it on OEM Sleeves.
Check these guys out - 885HP on OEM Crank and OEM Sleeves :
http://www.madtech.de
Its all about the tuning at the end !
