Last week i bought 240sx sr20 s14 engine in 13 car. the engine had low compression and it was missed firing so i took out the cames and i found a problem the the rocker arm was out of its position so i put everithing back on and i started it was still running like sh..t so next day me and my friedns change the head gasket it was running litlle better but after like 5 minutes it dies and when i was changing the head gasket a found other problem the exhaust lifter was moving i could push it in i didnt change it yet. But i have a question on u guys what can that be why is it dying??? Idk if the fuel pump is stock or not. and when i turn the car off and take out the key the fuel pump is still running thank u for comments.nissan 240sx s13 sr20 red top 300rwhpnissan 240sx s13 sr20 s14 hp????
i FIXED THE PROBLEM WITH DIYING IT WAS THE WATER TEMPERATURE SENSOR THE CABELES WERE BURNED IDK WHAT HAPPEND I JUST NEED TO KNOW WHAT CAN BE THE FUEL PUMP PROBLEM AND WHY IT IS RUNNIND BAD ON FIRST GEAR IT IS STILL OK BUT ON SECOND WHEN THE VTC KIKS IN THE RPMS WILL GO DOWN AND BACK UP AND I CANT FEEL THE BOOST THE BOV IS WORKING THROUGH
