dsm007 »
https://forums.nicoclub.com/dsm007-u28569.html
Sun Sep 11, 2005 6:14 pm
The coolant temperature could be the problem but I highly doubt it,it would have a hard time starting like start the engine several times and it cuts right out,if it was the coolant temperature sensor it would go away as the engine warms up,all the coolant temperature does is act the choke for our engines just like a choke did for the old carburated engines back in the day,except on out engines it detects the temperature of the coolant so the ECU can determine how rich or lean the fuel needs to be at startup....................anyways bro I am having the same problem here too as you,I just started up my SR tonight and drove her down the road,same problems as you,Im thinking its either a vacume leak or the MAF as the others said......make a boost leak tester and try her out,you will be surprised at what you will find...well room you now have two people to help on this board lol..........Levi
