sr20 running very rich
cody180sx
Car: s14 rb25det fully built 550whp coming soon
well i have a blacktop s13 and last friday i was running a 5.0 mustang. We ran a few times and on the 3rd pass the car started to bog between 2500-3000 rpms runs like a dead cylinder and really rich. Messed with the mafs and the ground and checked my vacuum lines nothing. I pulled my plugs and very nasty cleaned them up and noticed one of my coil packs was cracked on two places and i did the nail polish trick and i was about to see if that helped.
P.S. i beat the stang by a car and a half and he had a lot of mods.
cody180sx
well i checked ran the car nothing then checked for ecu codes threw a 55 a good sign lost i need help.
me fixing my car====>
cody180sx
well tried to pull codes again and got an 11 Camshaft Position Sensor is it bad or do i just try to adjust it or wat its not firing at all now like its turning over but no spark are something
doing this for 3 days now
mo20duane
Car: 95 Nissan 240sx
i know your pain. i just moved my ford lightning MAF back further away from my t3/t4 turbo and now my car drives, but still have rich fuel problem. blows black smoke out exhaust and idles like crap cuz spark plugs keep flooding. my next step if i dont fix it this way is to relocate my MAF if i can. If i cant do any of that, then i will buy an apexi ecu and have it tuned with that. that should fix the problem. with all the upgrades i have, i have to run iridium/ngk's IV. they work great. but this problem is annoying cuz i didnt have anything run this much wrong with the gt2540r turbo. but with that one, the MAF was alot further away from the turbo then it is now.
cody180sx
anything guys i don't know wat to do driving me nuts
cody180sx
well i took my valve cover off and replaced the cas and i smelled gas in the oil is this normal . Replacing the cas did not help. also if we wiggle the injector wires in almost starts then dies
cody180sx
anyone going to help its still throwing a code 11 cas out of ideas
cody180sx
well changed the plugs and it starts up. but idles werid unplug the mafs runs great but will not get past 2500 rpms but pluged in runs like crap and will not idle and only goes up to 4000 rpms. and its throwing a code 12 know witch is the mafs
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
sounds like you just answered your own question. sounds like a bad maf to me. swap it with a buddies, or find one in a junkyard or here on the boards. gas in the oil is a bad sign. could be your rings are on there way out.
codyace
Car: S14 w/redtop
Check MAF wiring
How far is MAF away from turbo
Change MAF (as said above) with a friend
Check CAS wiring, etc etc.
cody180sx
well i changed the mafs with one from the junk yard and it did not help so i took it back to see if they gave me a bad one and i think the gas was in the oil from it not starting over and drained into the oil that happens when it does not start on some cars i tried to start it for like 3 days strait
Modified by cody180sx at 10:52 AM 4/3/2008
Modified by cody180sx at 11:02 AM 4/3/2008
codyace
Car: S14 w/redtop
cody180sx wrote:well i changed the mafs with one from the junk yard and it did not help so i took it back to see if they gave me a bad one and i think the gas was in the oil from it not starting over and drained into the oil that happens when it does not start on some cars i tried to start it for like 3 days strait
What MAF are you changing it with, and or have in the first place?
Sounds to me like your car is in limp mode more thananyhting, due to this MAF issue.
Gas in oil isn't going to prevent it from starting, that's for sure.
cody180sx
well i used a 3rd mafs and that did not help so i'm down to it being a bad boost leak some were. on top of that fouled out another set of plugs thanks nkg for the crappest plugs i have ever delt with copper until i figure this crap out.
Had and changing it with the ka24e mafs
Modified by cody180sx at 4:09 PM 4/3/2008
cody180sx
checked all my couplers and stuff or leaks then checked the ecu again code 55 WTF!?!?!?
codyace
Car: S14 w/redtop
cody180sx wrote:well i used a 3rd mafs and that did not help so i'm down to it being a bad boost leak some were. on top of that fouled out another set of plugs thanks nkg for the crappest plugs i have ever delt with copper until i figure this crap out.
What are you running for management?
What injecotrs are you running?
NGK makes the best plugs out their for our cars.
Make a pressure tester out of PVC, and see what you can find.
cody180sx
every thing is stock370 injectorsstock ecui was just mad i broke another set of 40 dollar plugs( i can't drop 40 for plugs ever couple days) i think they are too sensitive. copper i could clean i they would be fine iridium nope i will not even waste my time cleaning them next time
well i found like the tiniest hole on the intake side on the rubber part right after the maf thats the only thing i did really and checked all my couplers
Modified by cody180sx at 10:34 AM 4/4/2008
srpowered240sx
did you fix it. unmetered air getting in or metered air getting out will make a big difference.
cody180sx
well i was running it was better still not great when the dang coupler blew off the hot pipe put it back on and alot of air was escaping tied all the way tight and still got air blowing by so i ordered a new coupler because the old one was a little big well i took the hot pipe off last night and i put it back on so thats y it blew off the first time but explanes the reason y it is getting a mafs signal to the ecu if air is leaking ands its reving to 4000 then no higher earler before the coupler blew off it would rev to 7000 in neutral
cody180sx
found it i run the stock side mount and the plug i put on the neck for the stock bov (i use the hks super sequential and hot pipe) blew off runs great now but keeps blowing the duct tape off i can't find a store around were i live that has a plug big enough
cody180sx
super duct taped works good now
