sr20 running rich
bootscut
Car: 1990 Nissan 240SX Fastback
I hear popping at the back of my muffler in both 1st and 2nd so Im guessing I am running rich.
I have 2 questions:
I am about to install a walbro fuel pump, will this add to the problem since I am already running rich?
I live in San Diego, is there a place or easy way for me to get this 'running rich' problem fixed? I read about this enthalpy JWT stuff in the other thread but Im really unsure whats going on lol.
Thanks
Neil
Car: shooting laser guns
There's a few things that can make a car run rich. The exhaust popping occasionally may not specifically indicate a static rich condition, however. The first thing that comes to mind is, are you running a blow off valve vented to atmosphere?
To answer your question a walbro fuel pump will not make it more rich.
bootscut
Im pretty sure my BOV has those characteristics. It is a stock S13 blacktop with no mods. Do you know how I can get this problem fixed? Will changing the exhaust be a possibility
Neil
recirculate your bov instead of venting it to atmosphere.
With it vented, in between shifts the turbo is pulling air through the MAF which the ecu reads as a signal to keep dumping fuel even though your foot is off the gas. this causes a momentary rich condition. also while cruising in vacuum the bov can 'float' open which lets in unmetered air and leans it out.
BoBa524
Car: 1995 Nissan 240SX SE
Neil wrote:recirculate your bov instead of venting it to atmosphere.
mine pops between shifts, recirculating the bov did nothing.
