SR20 Regrets??
silviaziz
Car: 1992 Nissan 240sx hatch-back
I'm in the middle of performing an S14 SR20 swap into my 1992 S13 hatch. I'm beginning to feel like this whole idea was a big mistake. I've spent about 10k in parts (including suspension and wheels), and the car is not even running yet. I purchased a front clip thinking that everything in my clip was from the same model car, and now I realize that I have a mixture of Zenki and Kouki parts. Hopefully the car will run fine but I'm having my doubts. My MAF comes from a Zenki and my MAF plug comes from a Kouki. I have a kouki wiring harness and ECU and a Zenki engine and transmission. My only real silver lining is the fact that my Engine only has about 15k on it and it is very clean (shiny aluminum when I look in the oil cap).
Do any of you guys have regrets? I now realize that I could have purchased a nice E36 M3 for about the same amount of money and I would have ended up with a much classier car, along with a nicer interior/exterior, not to mention decent speed and excellent handling.
duffman1278
Car: 89 240sx Hatch, the wildcats!
Should have done more research before you bought everything.
The clip should be all you need, and probably some replacement parts here and there but not 10k worth.
Should have probably bought wheels after the swap eh?
lrb_2000
Car: '91 Nissan KA-T hatch
Modding a 240 is a huge waste of money, but we all do it for the love of the car lol.. I've put around 12k into my car and it looks like s***.
ZX88
Car: s13
how can you tell theres only 15k on that engine. i seriously doubt than no offense. alot of time engine depot will say that but its not true. any used engine will need replacement parts.
nissan~240sx
Car: 1993 Nissan 240sx SR Blacktop...Finally Boosting
trust me, you wont regret it after you drive it. definitely worth the wait. i waited a year and went through two different motors before i got her running. also went through +$7000 to get it running as well. But its definitely worth the wait especially if you have never driven either another SR20 or a turbocharged car before.
Ninjamasta
My S13 Sr Kouki engine cost me around $2,000 -Greddy LS FMIC $500 -Greddy hot pipe with flange $110 -Greddy RS bov $160 Ebay special clearance price. -Godspeed Aliminuim radiator $240 -Samco radiator hose $80 -Stri DSCS gauges (boost, oil pressure, fuel pressure) $450 -Nismo motor and transmission mounts $240 -Peak performance transmission mount $60 -F1 racing flywheel and Stage 2 clutch kit $240 -used B&M shifter $115 -downpipe $100 -z32 front brake kit $550 (got ripped off here ) -new KYB Agx $500 -SPL Tie rod ends with z32 Tein inner rods $400
Total -----$5805
These are the parts I have so far...and more is on the way after swap. -Nismo power brace $140 -SPL tension rod $220 -SPL Ruca $240 -SPL upright metal bushing $120 -SPL rear LCA metal bushing $120 -SPL aluminium subframe bushing $130 -Energy Suspension front bushing kit $20 -Progress 30mm sway bar $240 -Godspeed rear 28mm sway bar $70 not too sure if they sell only the rearThats going to be close to $1300.Total after project $7100. Wow....Oh well I'm already half way there....but 10k with a front clip for your project seems a bit too much. You could have rebuild the KA and dump a T3/T4 on it, with AEM EMS.
slidestyle69
Car: 92 s13
between all my 240's since i was 16, i have prolly put 20k alltogether and nothing to show for it besides pictures, time slips and memories.
Do i regret it? Not one bit i could have had a nice tahoe paid for but its so worth every new part i put on my car. I LOVE IT
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
uuuuhhhhh.....
you dont sound like the prime candidate for a swap bud...its the easiest swap in the world to do...and 10K worth of parts, your car should be a head turner....did you buy 26" Work S2Rs?? lulz
nissan~240sx wrote:trust me, you wont regret it after you drive it. definitely worth the wait. i waited a year and went through two different motors before i got her running. also went through +$7000 to get it running as well. But its definitely worth the wait especially if you have never driven either another SR20 or a turbocharged car before.
**facepalm**
lrb_2000 wrote:Modding a 240 is a huge waste of money, but we all do it for the love of the car lol.. I've put around 12k into my car and it looks like s***.
**facepalm squared**
Koshin
duffman1278 wrote:Should have done more research before you bought everything.
this man speaketh the truth...
silviaziz
I know it sounds like I did not do much research, but trust me I did. I knew it would cost a pretty penny, and it would not have bothered me as much if I had purchased a front clip with everything I needed. The 10k includes alot; front clip, coilovers, wheels, tires, FMIC, clutch, flywheel, all needed gaskets, hoses, radiator, intake, elbow, downpipe, exhaust, test pipe, exhaust hangers, BOV, optima and battery relocation kit, brembo brakes, ss brake lines, hawk pads, ss turbo lines, ss clutch line, B&M short shifter, turbo timer and more. Also all the parts are name brand as well (I know I could have saved some money there but I wanted quality parts).
Also, the clip comes with the dash board, and the odometer reads 25,050 kilometers, which comes out to almost 16,000 miles.
Like I said before, the most frustrating thing is paying extra money for a front clip with zenki and kouki parts mixed together.
dtowndrifter
Car: s-14 kouki
i dont regret my redtop...but i think i should have gotten a s15 swap..
Yulaw
Car: 93 S13 240SX HB
You should've spent the money towards the swap only and then worry about stuff like coilovers and wheels after the car runs (unless your car was a non-rolling shell). When I had my SR swap done, I had a little few impulse buys here and there but wheels and coilovers are a bit too much to spend for a car that doesn't run yet. Those two will set you back about 2-3k. You could've bought an already SR swapped car and build it up even more but it's always fun to build it from stock.
Koshin
an S14 knotchtop SR swap shouldnt cost more than 3.5K, and if you do it all yourself...maybe 2,500 bucks
Ive got less than six grand in my car and Ive got more equipment than you and a legit car...
your car will be great when its done buddy, but you bit off to much in to short a time...
***hint hint*** you can get great buys on good used parts and it saves a lot of monies...
dtowndrifter wrote:i dont regret my redtop...but i think i should have gotten a s15 swap..
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
I would have personally got the engine in and running before I started dropping $$ on wheels and suspension. But just remember that it has been done before and is possible. Just don't cut corners and you will avoid many mistakes. I just hope mine fires right up once everything is in, but at the same time I am taking my time and buying the right stuff the first time.
TimTurboZ
Car: 95 S14 w/RBXX... 65' Mustang GT
Can you trust the cluster mileage with all those mixed Zenki and Chuki parts? (sorry if that shatters your world)
GL with finishing the swap! That moneys gone now so focus on being cost effective the rest of the swap and just think of the good times ahead
silviaziz
I created this post to see if others had regrets, not to be told that I should've done this or that. I purchased the coilovers and wheels because of the amazing deal I was able to obtain at the time. Also, I did not post everything I purchased, so it's hard for someone to say that they purchased more parts then myself.
Anyway, I'm glad to see that some of you also went through a lot and still think it's worth it. Only time will tell if I feel the same way.
TimTurboZ
Want to hear regrets buying a POS KA24DE from a douchebag and finally getting my car running after getting another motor. I put $1000 into a $500 shell...FML haha
S13Joe
Car: 92 Coupe
^ Shouldn't have bought a shell then, or at least compression test the motor before you buy it, jack a**.
Koshin
DirtyGhettoKids wrote:^ Shouldn't have bought a shell then, or at least compression test the motor before you buy it, jack a**.
yyyaaayyy yyyaaaayyyyyeeeee
bbwwwaaaahahahahahaha
you wont have regrets OP....once its running itll be bad a**...is the motor in the car yet?? w0t is in fact, the deal??
sebazztard
Car: 1992 Nissan 240sx rb25det project. 2000 Honda Accord LX DD. 1992 Nissan 300zx NA.
i dont understand how the biggest nissan enthusiast site, especially 240 gen has a thread like this. im more than looking forward to dropping 5k on my rb25 swap, and thats just in parts. i cant wait to dive into the project and fire it up for the first time, and take it for its first drive... i have to look up youtube vids to get my fix. maybe cars isnt your thing buddy? a friend of mine thought he was a car guy untill he realized he wasnt capable of giving it the attention it needed. i dont know how or why you are spending 10k on an sr swap, but i wish you the best in the project.
Koshin
seanman
Car: 1989 Nissan 240sx
dont tell him car building isn't his thing guys, obviously he was stoked to do it, just comin up on second thoughts. No regrets man, anytime something goes wrong on my sr, ya its a bummer, but i just kinda relax and start troubleshooting. Just take your time and do it right, and with all those parts, it'll be one hellof a drive once you step on the gas. you might have gone about it a little differently than the rest of us, but either way just stick with it and you'll laugh your a** off in hysteria when you go WOT in 2nd heh
sebazztard
seanman wrote:but either way just stick with it and you'll laugh your a** off in hysteria when you go WOT in 2nd heh
im looking forward to that lol
Koshin
youll get it done buddy...it will be worth it
SRs are my favorite motors
S14toRPS13
No regrets here, but just stay focus on your project. You've already spent the money and put in the work. Once it runs, you'll feel a huge sense of accomplishment and all your regrets right now will be a thing of the past.
silviaziz
Thanks for the back-up. I hope it's as good as you describe it. I only drove an SR powered 240 once, and it really impressed me, that's the reason I decided to do the swap. And as for being a car guy, I don't know many people who love cars more then me. I spend the majority of my free time reading/researching cars and have owned several modified cars in the past; however, this is my first project that involves an engine swap.
I am not performing the swap myself. My mechanic who has done about 3 SR swaps before is doing the install for me (I was told by the seller of the engine that I would lose my "warranty" on the engine if a certified tech did not install it). He has not ran into problems like this in the past.
My biggest mistake was trusting the local company that I purchased the clip from. I heard nothing but great things about them, so I had no reason to question them. When I saw the clip, I had no way of knowing that the harness and MAF came from a different SR. My friend purchased his SR from the same shop and had nothing but good things to say (he has an NX2000).
Well, you live and you learn. If I could rewind time, I would have done things much differently.
sommmatt
Car: 1989 Nissan 240SX
This sounds like I could go over there and have your car running in a few hours.
With a full front clip, seriously, it should be straight up bolt in.
Not doing it yourself is kind of fail too. If this guy has done 3 SR swaps, it should be cake for him. I don't understand why you're having these problems.
Mangid
Car: 1990 240sx sr20 5-speed
The SR in my car was put in 4 years ago for $2.5k with labor, out the door.
Sounds like you got screwed.
Dittoz7
Car: 1997 2f0WtY SE!
I'm Not Selling My Car Ever.
So I See All My Parts As A Life Investment Of Awesomeness.
