mackdaddy240 »
https://forums.nicoclub.com/mackdaddy240-u5555.html
Mon Nov 21, 2005 10:34 pm
Yeah I tried cleaning it, but it didnt work, I went ahead and bought another one. Problem still there, so after I got off work fixing other peoples cars I started on mine, here it is 2:30am and I'm very happy It was still missing so I pulled my coil packs one at a time till I found the miss, #3 so I cleaned the plug, very black way to rich. realized it had to be the injector, so I pulled the injector and the o ring was cracked pretty bad, put a new o-ring and problem solved, idles smooth, still a little rich because it backfires when I get on it and let off the throttle, i'm going to check the rest of the o-rings tomorow. Everythings good except that my idle speed motor is retarded At least I think thats what the problem is, when I'm running above 3,000 rpm and push on the clutch the idle drops to around 100-300 rpm and dies half of the time. I thought it was because it was running way to rich but that wasnt it. tried spraying carb cleaner and wd40 into the idle speed motor fresh air duct but didnt seem to do anything except make me gag. Anyone run into this??? any ideas would be very helpful. And thanks for all your help so far.
