SR20 redtop head noise VIDEO!! please help
mikecef2
Car: 90' Nissan 240sx (SR20det)
Ok so when I start her up it sounds terrible but then quiets but comes right back. I have a vid posted on youtube so you could check it out. http://www.youtube.com/watch?v=dzFMtaTLDRg If anyone has any ideas on what it could be please help me out!
EnjoiNismo
Car: 93 240sx
timing chain?
I'd take off your value cover and see if theres anything damaged.
mikecef2
It's not coming from the front of the engine at all it's coming from the middle exhaust bank but I'll check the chain anyways tomorrow
209sileightydrifter
Car: 1990 nissan 240SX
My sr was doing the same thing i found out that theres a guide in betwen the cam gears that often the chain slaps agints it causing that noise i was told that u can remove it to elimante the sound and it really wont do no harm to remove it
mikecef2
I did remove it and the sound went away. Now I am experiencing some other issues. Everytime I put it into neutral to come to a stop sign or what not, my car just dies right out. I also had two very loud backfires occur that stalled my car out while I was coming to a stop. I dunno what it is but it scared the ish outta me.
209sileightydrifter
could be a possibilaty that your chain might of skiped a teeth or it could be the IAC valve some times it gets oil in it causeing it to die at stops
mikecef2
the connector from the ignitor to the coilpack sub-harness was being pulled tight from the back of the block and was intermittently breaking contact. I removed the bracket from behind the head and pressed the connector together and viola! Runs and pulls like a champ
