snake240 wrote:if your just swapping shells keep your engine harness and ecu.
Well see I modified my SR harness in the 510 because you actually have to wire up the relays and s*** yourself, so I can't really take it out and use it in a 240. I was just reading that the 3 wire TPS's come on 5 spds. and the 6 wire ones like that SR in the 240sx has is from an auto. But where would whoever put the SR into the car I'm trading for get an Automatic SR? I've never heard of anyone having an auto trans on a SR. If I wanted to use the 3 wire TPS I guess I'd have to buy a new SR20 harness and get a new TPS since I've already switched TPS's with the guy. But I'm still not sure about the MAF, I haven't figured that one out yet.
Edit:
Another question. If I swap my TPS with his and swap my MAF with his, would there be any problem with that? I mean I heard the SR that was in the 240 run so I know it did work and it was wired correctly and everything. I guess it wouldn't be any big deal, but if the TPS ever went bad I don't know where in the hell I'd get a new 6 wire TPS. And then if I couldn't find a 6 wire TPS I'd have to get a 3 wire one and probably buy a new wiring harness. And another question. The 91-94 sentra se-r's have the same 3 wire TPS's as the sr20's. What would you have to do to change the 6 wire plug on the engine harness to get it to work with a 3 wire TPS? Or could you do that?
