Yes the T25 Mainfold will work with the T28 , including: T25, T28, GT25R, GT28R, GT28RS, GT2871R, GT2876R, GT3071R-WG, GT3076R-WG, etc. all the same flange
The stock mainifold is good for response and will spool quick cuz its a short runner, but if you want more top end power then a longer runner is what you want.
I would invest in some SS turbo line it will reduce the chances of stripping out the Oil feed line on the block.
if your SR come with the Stock elbows then no you wont need to buy new ones
CSUPUEBLOTIM wrote:The t28 will bolt up to a t25 manifold housing. They are in the same "T2" flange family. You will need to modify the lines for it. As far as the manifold swap goes unless your getting a high end one you might just want to stick with the stock cast one so you won't have to worry about cracking. You will also need a clocking adapter kit.
http://www.frsport.com/FRSport....html here is one option.
Clocking adapters are for ppl who have R/T SR and wanna install a T28 so clocking adapers are need to use the T25 outlets on the T28 turbo.Seeing that he is getting a S14 B/T the clocking adapers will not be needed
