Post by superman29 » https://forums.nicoclub.com/superman29-u125856.html Wed Mar 31, 2010 12:35 pm
Post by OkiDriftStyle » https://forums.nicoclub.com/okidriftstyle-u157146.html Thu Apr 01, 2010 12:54 pm
Post by nissan24009 » https://forums.nicoclub.com/nissan24009-u52571.html Thu Apr 01, 2010 4:55 pm
i dont think your right about changing oil a lot more! why would you change oil a lot more? its actually called a factory air/oil seperator. Oil fume comes up from the bottom through a hose. The separator keeps oil down and allows air to come up to the t-fitting in the valve cover. therefore you'll be changing the same amount of oil!!OkiDriftStyle wrote:that black box with the hose connected to the valve cover?? if so thats the stock oil catch can, it pretty much helps keep your oil clean from the blow by gas. you should keep that on there or get a aftermarket one or you'll be changing your oil alot more.
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
