Steady_One_S13 »
https://forums.nicoclub.com/steady-one-s13-u106202.html
Tue Jun 23, 2009 8:40 pm
TPS factory reading is 0.45 volts when the throttle is closed. Make sure engine is off. Check with a multimeter. Probe the middle pin with the red lead, then the black lead to ground. The reading should be around 0.45 Volts.If needed, loosen (but do not remove) the bolts to the TPS, and adjust til youget .45 volts.Hope that helps.
