theres no knock from what i hear but i agree check your intercoler couplers they might of just slipped off or what ^ said. glLonismos14 wrote:Say bye bye to the motor. from my laptop it sounds like knock.
O hold up check your intercooler couplers to see if you blown or ripped one.
+ 2.Obviously the motor is running on all cylinders. I would first do what Justin35ll suggested and then try a compression test.Justin35ll wrote:thats not a knock it's a missfire.
pull off the connector for the injector 1 by 1. If the idle doesn't drop down and stays the same you have found the cylinder with the missfire
yea im the guy with the sr... we pulled the plugs and they were very black and smelled like gas.. we did the injector check and it just idled worse for each one i took out.... the noise is coming from the intake side of the turbo... but we checked for shaft play and there was minimal side to side play.. idk wut else to try help me out...could it be the coilpacks or because my harrness is like a home made job lmk i need this thing runningHurryupandrunS13 wrote:If he hit fuel cut a lot, may have burnt up a plug..... Lean is the worst condition for an engine.
Also if you dont have rocker arm stopper, and it spun up to 7800, you may wanna check the top end
Modified by HurryupandrunS13 at 11:13 AM 2/10/2010
?huh?nissans13240sx wrote:
