Sr20 Problem!!!!!
implict
Whatever this is its blocking my steering... ( the metal hose )
Most of the engine pics ive seen.... has this removed... what do u buy to replace that?
AllTurBo
Car: 94 red drop top w/SR
it's the AIV system, get rid of it. Make sure you plug the hole on the O2 extention with a BUNG plug though.
implict
where can i get that plug?
implict
also what about the lil black box next to it on the right?
AllTurBo
I don't know what that box is but I kept it on my motor. You can get the plug from Heavy throttle for like $2.00 or it comes with the install kit, which also includes new belts and hoses..etc. You might be able to fill it with some JB weld or go to a hardware store and find a plug that big, but I am not sure what diam/pitch of the plugs is. The Install kit from HT is like $100 and it comes witha bunch of random stuff that you may/may not wind up using.
implict
k, thanks alot
Jeff
pampadori
Car: 91 Nissan 240SX coupe
keep the black box too. it is a oil separator. it catches oil from the blowby and keeps it from going out the valvecover "t" and into your intake (why some turbos are full of oil when you get them).
or if you are using the k&n breather, it keeps it from spraying out of it.
shaun
Cyberkreig
Car: 1993 Nissan 240SX SR
I'm confused. Arent you describing a catch tank? I thought aftermarket catch tanks like the greddy attached to the other half of the "t" ?
pampadori
that is true. they do attach also. the black box oil separator will GREATLY cut down on the oil that gets to the greddy catch can or whatever you use. greatly, not totally. there is still blowby that comes out of the valvecover too. mostly from the block tube, but some from the valvecover vent. shaun
Cyberkreig
Thanks for the info. I always wondered what that box did. I guess i should maybe empty that every month or so?
pampadori
empty the black box? no, it drains back down to the block after the blowby pressure is less then the gravity pushing the oil against it.shaun
240_Keyy
Car: '90 240 Fastback
you can also use 2 nickels in the hole and then impact the big nut back onto it. This will crush the nickels and make a hella nice fit.
I have mine like that and it it "A OK"
implict
so u crushed to nickels into that?
BuudWeizErr
240_Keyy wrote:you can also use 2 nickels in the hole and then impact the big nut back onto it. This will crush the nickels and make a hella nice fit.
Thanks for pimping out my idea ;) kekekekeke ^_____^
240_Keyy
BuudWeizErr wrote:Thanks for pimping out my idea ;) kekekekeke ^_____^
Yes this is Ryan's idea, give him the credit. I think nickles were made for the sole purpose of going into that dang ol hole. :)
Drakon
Car: S13 hatch-SR+bpu's
he he my last name is nichols hehe
I H8 UR DSM
GHETTO FABULOUS!!!
I H8 UR DSM
Oh, besides, your messing up the whole economic system by taking two nickles out of rotation!!
implict
damn how did u guys get ur a/c to hook up?????
power steering is being a ***** as well.
kevin240
The plugs are a special size in metric (so they can't be easly pluged) I have plugs that we make up here. $10.00 to your door.
