idamaster »
https://forums.nicoclub.com/idamaster-u140423.html
Mon Jan 18, 2010 9:25 am
It will turn over, hesitate to start then not start. I can get it to start if I pull the fuel pump fuse, start the motor, let it die, then put the fuse back in and start it again. I just changed the plugs today thinking that that was the problem . Just took the car out for a drive. Started fine at my house 2-3 times. I get to where I was going to go, turn the car off come back 5 minutes later and try to start it and it happens again. I use the pull the fuse process and I drive home turn the car off and right back on a second later and it starts with the starter grinding. Once the motor starts it will run fine.
