compactfean »
https://forums.nicoclub.com/compactfean-u148941.html
Sat Jan 22, 2011 5:20 pm
Oh! Ok, you are getting ready to do the swap! Lol my misunderstanding. I thought you picked up a car swapped already. Me personally replace all intake and exhaust gaskets including Turbo gaskets and throttle body. Rear and front main seals and valve cover gasket. All the coolant lines. New fatty oxygen sensor, and plugs. If the trans is mated then seperate the them and thoroughly check clutch and flywheel when doing the rear main seal.
