Condorinator »
https://forums.nicoclub.com/condorinator-u240772.html
Tue Aug 26, 2014 11:09 pm
Sorry to bother you guys but it's getting a little crazy. Long story short, after getting stationed in Hawaii I made the mistake of buying a 40 with an sr already in it then doing it myself like I should have. I've done two sr swaps myself so I thought some one else's work would be up to par. Wrong. I drove home this missle coupe on 3 cylinders thinking it was just the coil pack, back firing and bogging about 20 miles.... Coil pack? Wrong. Bought a new one and slapped it in. Didn't work. I changed the spark plugs, noted that number four plug was covered in fuel. Changed out the ecu with a e5 instead of the 62, nope, just ran worse... and lean. Changed the ignitor. Still no dice. Timing on point and and CAS dialed in. I'm kind of at a loss. I've got a multimeter but i haven't checked for continuity yet, mainly because I'm not sure what to look at. I checked the pins on the ecu and harness and everything has contact. I bought a whole new harness and i'm thinking about rewiring the whole motor, but i'm about to get redeployed so I'm really hoping it's not that because I want to spend time with my family. Any ideas will help, thank you guys!
