sr20 passing smog
djmonk
can anyone tell me how you get a sr20 to pass smog in calii read the laws and it sad you have to use a same year or newer engin.and that it must not produce more emmisions than the original..i see alot of people say they will not pass but i see alot that are smogged so can anyone tell me how
180fan
Car: 89 fastback
SR's are not legal in CA for use in 240sx. Get it through your head and learn to deal with the possibility that you might have to find someone that can hook you up with a smog.
That said, here's the how to.1. Find someone who'll pass you out the pipe. AKA overlooks the visual and doesn't rat you out for no EGR, and possibly other emissions equipment.2. Make sure you've got a 3 way cat on. Catco is a 2 way, you'll need the 3 way.3. If you've got headwork, forget it.4. retard the timing one or two degrees5. a towel over your air filter. You'll need to adjust this with pretests to find the optimal position.6. try using alcohol. It'll help a bit.7. pray to whomever you pray to.
240sxHitman
Car: Boosted '91 240sx
what excatly is the EGR and im guessing it cant be saved and adopted to the sr
SpeedRacer1
Car: 1990 240SX, G35
EGR = Exhaust Gas Recirculation
It cannot be used because the EGR pipe runs right through the steering column. You can relocate the pipe to keep the EGR if you really want to.
240sxHitman
SpeedRacer1 wrote:EGR = Exhaust Gas Recirculation
Oh ok, i mean i would but it for the visual part of inspection, im in new york not cali and i know cali has certain different regulations
