tommey wrote:Its m12 x1.25 if anybody needs it.
Fixed it with helicoil.
Hey Tommey, I tried to private message you but apparently I haven't been active enough
Hopefully you get this and dont mind answering a few questions for me. I know this thread is older than dirt but maybe youll remember.
Did you use the fsm torque specs after the helicoil and did it hold? Did you only thread in the coil as far as the bolt would reach into the oil gallery? Last but not least, How did it hold up in the long run? Any info would be appreciated.
Also thanks for the bolt specs !
