codyace »
https://forums.nicoclub.com/codyace-u28194.html
Fri Dec 31, 2010 1:05 am
There is nothing more fun than tearing the front subframe out, the pans off, and then trying to reseal the oil pump in car.
FWIW: You can almost BET on the upper (between head and oil pump) seal not sealing well.
As said here, remove the engine and do it that way. By the time you tear apart the lower suspension to do it, you could have pulled the entire engine with the harness connected (just unbolt it from ecu, push it out firewall, done!) and worked on it on a stand. Plus that way you won't need a realignment.
