sr20 not starting
turbo junkie
Car: s13 240sx
So I was driving my car winding out 3rd, shift into 4th and the rear locked up tires started chirping, throw the clutch in and shift to 5th. The motor dies and wont fire. Motor wants to turn over but not firing. I need help!
fregisr
Car: 240sx 1990
when you says, want to turn over, you mean turns like normal or with hesistation. If it's with hesistation then you probably threw a rod
turbo junkie
Car: s13 240sx
When I try to start it, it cranks but doesnt start, it seems like its choking out like it's not getting air, my friend thinks it jumped the timing, but I am not sure, i am going to take the valve cover off tonight, and check the chain
Morph
Car: 91 Sr Powered Coupe
Ecu Codes???
theman631
Here is a picture for checking the timing if you wanted it.http://www.frsport.com/sr20det....html
Hope it is an easy fix, Jimmy
