azsilvia_s13 »
https://forums.nicoclub.com/azsilvia-s13-u149945.html
Sun Dec 05, 2010 3:23 pm
ok i just finished my sr swap few days ago it was running Icreadibly well... but let me just say i had a lot of problems with this swap i had to re do and re pin the wireing harness. It took me about 3 days to get the car running right. Now to my problem. I was driving back from the car wash and i heard a POP and my turbo stop spooling, I inmediatly tough the waste gate is gone, so i got home let it cool down and started checking the turbo set up, i checked the TBC, i bypassed it ,with no luck, checked the fins, shaft and waste gate door, and found no problems, but a little shaft play on the turbo. I put everything back together and wired the waste gate closed to see if i could spool the turbo, but nothing. i dont know what the problem is i checked ic piping and vacumm with no luck, so right now it runs but like if it was na. It zeros out by boost controller and it stops there it will not build pressure at all, any imput will help me a ton...
