xyoufailmex »
https://forums.nicoclub.com/xyoufailmex-u25588.html
Wed Dec 27, 2006 5:08 pm
Well, I drive the SR20 home for the weekend, 200 miles round trip, runs GREAT. The only problem out of the car I have is a few small leaks, and I have to pound on the gas to get her to crank during cold start. It eventually catches and idles fine. I drive home last night, get up this morning, crank her up, and drive it to work. I get there, no problems, I park the car, turn it off, and leave the turbo timer to shut her down as I go inside. I come out to crank it.... nothing. I pound the gas some, figuring it will catch. Nothing. I continue this, nothing. I check for fuel, and again nothing. The pump isnt pumping. We check the wires going to the pump, no fire. Check the pump using a hot and a ground, and squirt squirt, it pumps. We install the pump and start tracing wires. Fuel pump relay (EPI Pump? whatever) and no clicky, fuel pump fuse is fine. Theres 2 fuses there, both which are green and have EPI and EPI pump, or whatever weird name it gives. We replace the fuel pump relay, and it clicks now, but no fuel. So we swap the relay around, and no click from either. So we swap em back, and now the fuel pump relay wouldnt click.
So, we hotwire up the pump while its in the car. I get my friend to touch it to the hot post of the battery and I crank. We can hear the fuel surging through the lines, but still no crank. So I obviously have no spark or anything either. I just got the car, so I performed none of the modifcations to it, leaving me clueless on where to start. Could it be an issue concerning the turbo timer? The only reason I ask, is it was the last thing to have control over the car. Ive done all I know... so I ask you guys.
