Its quite easy. They go under the valve cover and attach to your camshaft brackets. They have fingers that hover over the rockers to push them back down if they happen to pop off. On s13's there is a plate on the exhaust side that you have to grind a tad bit to make them fit easily. They will probably fit without grinding the plate but the bolts may bind a little when trying to put them in their holes.deathBooster wrote:I never thought of that.. i found couple.. they are not expensive.. but.. where do they go?? is it hard to instal?
No they don't go on the rockers. They sit above them. Why do you have to be so condescending? It was a simple question that you obviously didn't know the answer to. So ummm well ummm so ummm ummm well (<--- look familiar?)...FattyMcBaggins wrote:well, they're called rocker arm stoppers...so...well...they kinda go on the...rocker arms...so they can...um...stop them from flying off
Owned.NoStickers wrote:No they don't go on the rockers. They sit above them. Why do you have to be so condescending? It was a simple question that you obviously didn't know the answer to. So ummm well ummm so ummm ummm well (<--- look familiar?)...
the gt2871r that is......spider_slayer wrote:gt2871r. its the answer to everything.
a bigger turbo is always the right answer when modding the engine. sure it takes a new fuel system and a standalone and countless other things but the newb will figure that out for him self upon some research.BurnsAuto90 wrote:Whatever you choose to do, do it right. A bigger turbo isnt always the best idea and can sometimes scatter an engine..
