SR20 Mass Air Flow on CA?
TheSilviaGuy
hey, I have had computer issues and had to swap out the tuned ecu, now with the new ecu, it won't read my RB26 MAF. I am selling this car soon so I'm looking for a cheap-ish fix (ie. no safc or sending the ecu out), and I would also like to keep my RB26 MAF for my other Silvia. So, I have a spare SR20 MAF and was wondering if I could wire it up somehow? I found a way that a KA-E MAF would work. But I don't have one on hand. If I can't wire up the SR20 MAF, I will go the KA-E route.
boost_boy
TheSilviaGuy wrote:hey, I have had computer issues and had to swap out the tuned ecu, now with the new ecu, it won't read my RB26 MAF. I am selling this car soon so I'm looking for a cheap-ish fix (ie. no safc or sending the ecu out), and I would also like to keep my RB26 MAF for my other Silvia. So, I have a spare SR20 MAF and was wondering if I could wire it up somehow? I found a way that a KA-E MAF would work. But I don't have one on hand. If I can't wire up the SR20 MAF, I will go the KA-E route.
Go the KA-E route and forget the SR20 crap.
TheSilviaGuy
I've got a KA24E MAF now, but my friend could not find the connector on his harness and neither could I. Is there anything I could try to do to wire up my SR20 MAF for now? I'd like to get this car moving asap. The SR20 MAF and KA24E look the same, but have different part numbers and different connectors.
I may look into ordering just a connector, but being such an old vehicle, I doubt I'll find anything.
boost_boy
TheSilviaGuy wrote:I've got a KA24E MAF now, but my friend could not find the connector on his harness and neither could I. Is there anything I could try to do to wire up my SR20 MAF for now? I'd like to get this car moving asap. The SR20 MAF and KA24E look the same, but have different part numbers and different connectors.
No. Don't even bother. If you can't find one, I have a KA-E AFM that I'm not using. Don't go experimenting or you may make matters worst.
float_6969
You can't use the SR20 MAFS on the CA. It'll run like crap. The KA-E MAFS might work, but it won't run great. There isn't a direct replacement for the CA MAFS except for another CA MAFS.
Anu
Car: Nissan 200SX s13
I am running a CA18det on an S14 MAF ( partnr S14-RNN14-W10-SR20DET), but my car has been mapped for it. I dont think it will run at all on a stock ECU.
s1390
Car: 1990 240sx Silvia front end conversion ca18det swap gt2876R
float_6969 wrote:You can't use the SR20 MAFS on the CA. It'll run like crap. The KA-E MAFS might work, but it won't run great. There isn't a direct replacement for the CA MAFS except for another CA MAFS.
People switch over to Z32 MAFS all the time and i know your right that there isn't a direct replacement for the CA MAFS except for another CA MAFS but other MAFS will work
float_6969
Other MAFS will work, IF you tune the ECU to accept them, or use a piggy back to modify the signal. You can't just wire one up and have it work.
s1390
So just curious what would the symptoms be if someone had the wrong MAF wired in? Would the motor spit or backfire because i have a friend with a ca and it spits at idle.
boost_boy
s1390 wrote:So just curious what would the symptoms be if someone had the wrong MAF wired in? Would the motor spit or backfire because i have a friend with a ca and it spits at idle.
He should check his computer to see what code is being displayed. If he is running an AFM other than the one the ecu was calibrated to operate, then he is going to have a disgruntled car.
s1390
Your 100% right.. I checked the part number on his MAF and this is what I found 22880 40F00 AFH50-04
s1390
I was also curious if anyone has switched to a MAP sensor and if it is possible to do with nistune
float_6969
Easiest way to run MAP is to switch to a standalone. I'm running an SDS EM4-F and I love it. I'll never go back to a MAFS again.
s1390
Thats awesome thanks for the info
