SR20 Main Bolt Torque spec?
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
blondstrat57
Car: 93 240sx Vert, 94 Z32 Vert
Anyone know the torque specs for the main bearing girdle/cap bolts? I found 28ft-lb with and additional 45 degrees,,but it this dry or with lube?
Is it the same for the GTir bolts?
Also need the torque spec for the little piston oil squirters (kinda bad if this falls off).
Are these posted anywhere?
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
