SR20 MAF Problem - a new side effect
s13_chris
Car: 90 240sx Hatch
My MAF seems to be acting up. It has happened a couple times before but it does the 2500RPM rev limit safety mode. Well before I turned the car off and kinda jiggled the wires around on the MAF and it seemed to resolve itself. And today when it happened I sprayed some MAF Cleaner on it and it started up. Drove it home. Turned it off for about 15 minutes. Came back outside and it was in the limp mode again. Cleaned and checked ECU and its code 55. Wont get above 2500rpm..
So new MAF time?My intercooler piping is hooked up completely
Not sure what else to check. I need to go to work so any help is appreciated.
InsaneIrishTrash
Car: soon to be 89 240sx fastback
55 means there are no faults codesi would replace maf to start but i have heard of few other things that may cause this to happen unplug the maf try it then see if it still happens if it does you know you will be looking other parts as well sorry it all the info i have but will try to help gl man
Modified by InsaneIrishTrash at 10:15 PM 6/19/2009
theengineguy
Car: 1995 240sx se
pull the maf plug off and inspect for bent pins, corrosion, or spread female side terminals.
if you can consistantly wiggle the maf wires and get a change your problem is more than likely there in the wiring not the maf itself
