float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Tue Feb 27, 2007 9:26 am
The KA-E and CA18 MAFS are similar enough in size that they are usually interchangeable. I believe the SR20 MAFS is bigger than the KA-E, and if used on the CA18 may cause problems. If a bigger MAFS is used with out compensating for it, the car will run lean. To compensate you can increase the fuel pressure. If the MAFS is a big enough increase, you can increase the injector size a proportional amount and get the same effect.
Regardless, you would want to use a SAFC to fine tune it.
