sr20 maf- need info.
s13_chris
Car: 90 240sx Hatch
well sometime today my maf decided to f*** up someway somehow. I havn't done anything to it recently that would mess with it at all.
I have switched MAFs with a known working one.I rechecked all connections by the ECU.I cleaned my maf and light tested the maf plug.one of the pins inside the plug does show power but the other 2 do not. my codes are 55 but sometimes code 12 (when its unplugged) and i got a knock sensor, code 34, a couple times. But it goes away when i turn the key on/off.
i dont know waht to check anymore. contemplating getting z32 maf but will it solve the problem?
zach-Ka
Car: 1990 240sx (SR)
Have you gone through and checked all your wiring?
