Second Shadow wrote:I would get a fuel gauge first, they're cheap and easy to install and will tell you if you have a fuel pressure problem. also, check for vacuum leaks after the maf but before the turbo. a leak there will allow air to get into your intake system without going through the maf first, making you run lean.
yeah its capped, my bov is ventingSecond Shadow wrote:are you sure? most intake pipes in addition to the port for the line off the valve cover(as they are based on the stock one) have a small nipple on top and a second larger port hidden on the bottom for the stock rercirc valve. this is typically capped off if you have an after market bov.
I only bring this up because if you didn't already know it was there that second larger port is next to invisible. ( it happened to me).
PyR0NiAk wrote:Upgrading to a 255 is something that honestly should be done when you do your motor swap, so now would definitely be a good time to do it, as I stated before. They're like $90 shipped from a nico sponsor. Check the advertiser's market. And if you're super strapped for cash, Enjuku sells the isis version even cheaper. As far as the aftermarket fpr, I got my used one with a gauge for $20, so once again NOT expensive. These are all things that are smart to have anyway.
I'm not saying this because I think what shadow is saying is wrong. He's 100% correct in how that COULD be causing your problem. I just think it's unlikely considering you even said you were running on a 200k mile fuel pump.
