SR20 KA clutch
psyduck
Hi alli currently have a 95 zenki and my clutch is super worn. i need to replace it, however, i'm also planning on getting an sr20 soon. if i get the sr20 swap, does it come with a new clutch? or is there a good clutch i can get that's compatible with both the ka and the sr?
Blown240sx
Car: 1996 240sx
most SRs come with a clutch but its usually very worn. You might get lucky and get a good clutch.
No the KA and SR are not the same. SR uses a 87 Maxima Clutch.
psyduck
should i just get a cheap generic clutch for now then? for my ka..?
ILikeMy240sx
Car: SR Power
if You are going to get a SR soon, I wouldn't bother with a clutch change on your KA unless it's worn out so bad that its not driveable. The reason is, when you get your SR, you will most likely have to change your clutch. Actually, you NEED to change the clutch becaue doing that while the motor still in the car sucks.
