Mr. White »
https://forums.nicoclub.com/mr-white-u164864.html
Sat Aug 06, 2011 4:30 pm
Okay so, I finally found an intact body harness for my car. I threw those in (inside and engine bay harnesses) and hooked everything up.
So i tried to start it. I got power but when I went to crank it, I did nothing. great. So I left it for the night since it was getting dark. The next day I go to start it, I got no power as if the battery was dead. which it was.
I had someone help me jump the car, this time when I tried to start it the starter just clicks and clicks rapidly. So I tried to start it with a screw driver and it did the same thing. just clicks. Then, I tried hitting the starter with a hammer and I get the same results. I'm really stumped.
The harnesses I put in are from a dual cam car, but my lower harness is the same one the car has had in it. the car is a 90. on the lower harness, there is a connector that doesn't go to anything on the new harness, but always went to something on the old harness i had. I has four wires coming from it - a black, red yellow/blue, and I can't remember the last. The motor is a Sr20det with an S13 block and an S14 Kouki head.
Could really use some help!
