sr20 instalation help
implict
well boys... the ka24e is comming out and in comes the sr20det. Already went to heavy throttle and looked at the install FAQ's. Just woundering if anyone has anything else to add since im gonna be doing the swap myself. This is my first swap. Got a whole front clip so i should have every part that is needed for the swap.
Any tips lemme know ... thanx
S13240
Nothing...just drop in the sr in engine/transmission together. Be sure to drain your transmission fluid b4 you take off the driveshaft of you're gonna have a mess under the car where you'll be going under some more. Good luck!
BuudWeizErr
^^that happened to me... doh!
Take your coilpack cover off, you might damage it when you are dropping the engine in.
Dropping it in is pretty easy, you shouldn't have any problems... hope you got your P/S lines in already if you are switching to DOHC P/S. It's not fun getting them on with the engine already in.
slw240sx
Car: 1990 Ca18det 240sx Hatch
take the shifter out also !!! that helps the clearance on the transmission !!!! BUD, thank god i thought i was the only one who didnt drain the transmission !!! i dont feel as stupid now !!!
Ace
Car: S14
You should probably take off the emmission control devices like the EGR canister (I didn't but am looking into taking it off.) Also the AIV has got to go if you haven't already taken it off.
implict
so drain the transmission, do the p/s lines, and remover the shifter?
I H8 UR DSM
Use a lot of lube.
lol
jk
JESSERPI
