sr20 in fiero need help
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
jturbo06
im planning on putting one in my 86 fiero and was wondering what fwd transmission that uses a cable linkage will work with this motor? i'd like to use a spec v 6 speed but no clue if that will work. please help
nametakennow
Car: '06 MINI Cooper S
I've heard of a Spec's 6spd being modified to fit an SR, but it'll take some fabrication (not than an SR'd Fiero isn't a big project to begin with).
No room for a shift rod? IIRC there aren't any SR's that come with a cable shifter stock.
jturbo06
are there any fwd trans that would bolt to it with the cable? like in older model sentras?
boost_boy
jturbo06 wrote:are there any fwd trans that would bolt to it with the cable? like in older model sentras?
That's a negative my friend. Older sentras use shift rods. No nissan fwd cars that I know of use cables.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
I've only worked extensively on one FWD, so someone explain the differences in shift rods and cables.
poweredbyNismo
Car: 1996 Nissan 200sx (project)
you can probably use an sr20ve 20v trans.
its also a 6speed.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
