Well obviously. I'm not a complete idiot. I don't get on it for one, but I do have the right settings in the SAFC for the Z32 maf. Thing is the car idle'd fine before I changed the timing to the correct degree.dc1984 wrote:i believe that around 20 vacuum is normal. i dont realy see anything wrong with an 800 idle. but fyi, u changed ur air sensor and havent tuned for it yet, u might want to do something about that before u start having worse problems.
think about it like this, anytime u mess with the air or fuel in your car, u need to tune for it.
800 idle is fine, what did it idle at before to make u think that 800 is not good? for the low vacuum, check for vacuum leaks, that is probably the case. as for ur maf, get it tuned. those settings u put in doesnt do anything for correcting any fuel for the change in the mafs.good luckSlammed95S14 wrote:
Well obviously. I'm not a complete idiot. Thing is the car idle'd fine before I changed the timing to the correct degree.
