SR20 Idle problems
89DOHC
got the SR20 in starts everytime.. dont have the proper intake ATM but have one that seals and that fun stuff to make air flow proper but now the problem is. it idle like **** and is running real rich *black exhaust i think that is rich i get emm mixed up* my question is what can i check and what wires should i check my dad thinks it has something to do with we possible missed a wire somewhere that controlls the air/fuel ratio but i have no idea any help is greatly appreciated thank you ahead of time
89DOHC
bump i need help :(
yellow_jacket
Car: 95 240sx
Are you sure you don't have a boost leak(or vacuum leak in someof the piping.
I H8 UR DSM
u have an o2 sensor?
89DOHC
we have checked the lines so vaccum leak getting 20 mercury reading constantly for boost and no we done have a o2 sensor.. i am guessing that would make a difference?
BuudWeizErr
the o2 sensor tells the ecu how rich or lean the car is running and adds more or less fuel appropriately. So yes, an o2 sensor would make a difference, aside from the fact that they are supposed to be there.
I H8 UR DSM
Yes, its good to change when doing the swap....even better to have one in the first place, lol....go get a 300z o2 sensor, and let us know how it works...
jessehttp://www.rollhard.com
SR Sil80
Car: Cars, computers. gaming, web design, etc
Hey (new to these boards) the car 89DOHC is asking about is mine. Anyways We would be needing the o2 sensor out of a 300zx turbo or NA? Or would it matter? Thanks for previous help and in advance for any more help.
SRBURG13
Car: Cars
Would the o2 sensor just drop in, and then just let it be? Any modifications to be done?
Cyberkreig
Car: 1993 Nissan 240SX SR
You might wanna do a search on it. In my notes about the SR I have that it is an 89 300zx Turbo. and that that item is a direct replacement.
joe3180
Car: 89 240sx, S13 sr20det, silvia conversion
i kinda had the same prob....do you have a stock blow of valve?
89DOHC
nope not much on this swap is stock to tell you the truth just the turbo and internals are stock everything else is aftermarket
