sr20 guys I need your help!
pearlS13
Car: 90 240sx
If someone with a s13 sr can do a very simple test for me i would greatly appreciate it. I'm looking for a voltage reading from a specific harness plug....its the plug that bolts to the side of the valve cover thats for the coolant temp sensors/tps. If someone can test the harness side of that plug and give me their voltage readings that would be great. I don't need the actual voltage from the sensors...I need the voltage on the ecu side of the plug...so basically with the key on the ON postion test to see what voltage the plug is getting from the ecu. BTW...one of the pins is obviously a ground so I just need the voltage your getting from the other 2 pins.
Thanks.
n!smoluv$13
man i wish i could help but i dont have my sr yet
