SR20 GT2860RS oil drip / gasket question
boostedoxide
Car: 93 240sx SR20-GT2860RS turbo
93 240sx with a sr20 blacktop swap. turbo is a garrett gt2860rs and is dripping oil somewhere. pulled off the lower oil return line going from the bottom of the turbo back to the block and saw this /
shouldent there be more of a gasket than this?
I cant track down whats causing the oil drip so i am going to replace the factory bent metal oil feed/return lines with braided stainless steel hoses.
could anyone tell me what size hoses i need and what the correct sizes/trims are for the gasket i need to order?
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
There definately needs to be a gasket there. I want to say its 1/2 line for the drain tubing. Check out frsport, they have every thing you need.
