SR20 fusebox wiring help?
4wheelsfor2
I have a hardbody that has an sr20det swapped into it, the only problem is that the harness was cut going to the fusebox, and i don't even have the fusebox. the rest of the harness is intact going to the ecu and all the sensors and whatnot. Is there a different harness that can be used? a friend said possibly a ka24 harness, but were not sure, or is there anyone that has a good wiring diagram for the fusebox? it is a redtop sr.
GoTRicEo0
Car: Slowest crap the earth have ever seen.
POST PICS. :D~Edit. Deleted everything I wrote =/ Which part of the fuse box are you missing?
-Jeff
