Sr20 fuel pressure prob
sr kid 88
Car: 91' sr240
Ok need some input people. My car is gettin tuned right now on e85 and my tuner told me that my fuel pressure keeps failing so he can not complete the tune till this problem is fixed. The car is a fully built sr20det top to bottom. We already put a new fuel filter and Areomotive afpr. I have 1250cc injectors and a single 255 fuel pump. Gonna try a new fuel pump Friday and see if that's the problem. Any other suggestions? Thanks in advance
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
sr kid 88 wrote: I have 1250cc injectors and a single 255 fuel pump.
I don't think that a 255lph pump can move enough fuel for those injectors. Guessing that your running about 25 psi of boost, you'll need something that can flow up to about 400lph at 75psi if you are running up to the limit of the injectors. I'd check out Aeromotive's A1000.
sr kid 88
Car: 91' sr240
Yeah that's what I was thinking. Ordered the Bosch 044 to run it inline with the 255. Thanks for the reply
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
sr kid 88 wrote:Yeah that's what I was thinking. Ordered the Bosch 044 to run it inline with the 255. Thanks for the reply
That was the exact setup I was going to recommend.
