Sr20 fuel line/downpipe sizes
devsbeater
I keep forgeting to measure the 3 bolt flange on my t25, just wondering what size it is so I can order one from work, cause I'll probly forget tonight again.
Also, what size fuel line would be ideal, especially if I'm gunna be upgrading the injectors and stuff later? Should I go for 3/8 or is 5/16 fine?
Thank You very much
david200095367
Car: 91 fastback 93 coupe w/s14 sr20det 98 s14 kouki
if you are using stock turbo elbow im pretty sure its 2.5 in and the stock rubber fuel line im pretty sure is 5/16.
devsbeater
thank you
