C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Wed Jun 25, 2003 9:44 am
Tube-fin designes are typically more efficient. The Bar-Plate designs allow better flow through the core as the opening for each channel is flush with the end of the core itself. The tube-fin design sticks out a bit, slowing airflow some. The slower the air goes through a core, the more time it has cool.
Both designs can use internal fins. And each can have varying fin density, which is really where a lot of pressure drop vs efficiency compromises can be seen.
As far as airflow to the radiator, the tube-fin generraly does better. Part of it has to do with the shape of each channel. A tube-fin tends to have rounded channels that allow air to go smoother through the face of the core. Bar-Plate I/S's have a flat face which is not as aerodynamic. Tube-fin designs tend to use thinner channels, so more air can pass through to the radiator. The ambient turbulators also tend to be less dense as well.
In defense of the Bar-plate, it is a heavier unit. The metal used is thicker, which makes it more durable to road hazards(tire tread, rocks, debris, small animals, etc). And because it has more mass, it can absorb more heat before it experiences heat soak. Though, if you size properly, this should not be as big an issue. Bar and Plates tend to be more flexible as well. Most Tube-fin are long and typically have similar dimensions. Bar and plate are easily modified for different size requirements. You can also either run horizontal or vertical channels. In a typical FMIC set-up where the I/C is wider than tall, you can run more channels by running a vertical set-up and get less of a pressure drop with the same efficiency.
There's no simple answer to which one is better. It depends on several factors. It's really a tough call. There are several different tube-fin designs with different turbulator design and densities, and even some with offset channels like the APEXi' intercoolers. The only Bar-Plate manufacturer I know if is Spearco, and unfortunately, their cores all seem to have the same turbulator densities. But if you can find some with different densities, there can be some more fine tuning to the needs of the car.
