sicj »
https://forums.nicoclub.com/sicj-u95487.html
Wed Jan 14, 2009 11:35 am
So we all know about using the SR20DET flywheel/clutch for a broader selection of parts.
Most of use the SR20 Fidanza aluminum flywheel.
Now, in the Driftopia How-Tothey talk about adding washers to compensate for the flywheel thickness difference between the stock CA flywheel and the SR flywheels so the stock flywheel bolts can be reused.
Some people have had experiences with the starter grinding on the flywheel ring gear and not meshing smoothly. I believe this has to do with improper spacing of the flywheel and the differences between the two. The SR's overall diameter is larger than the CA's which is also contributing.So I made some measurements and calculated a rough shim thickness to space the new Fidanza flywheel out to the stock CA flywheel offset.This should help with the engagement for the starter since the Fidanza flywheel ring gear would be set at the same offset as the stock CA flywheel.
.100" is close to 1/8"1/8" = .122"
note: the Fidanza measurements were taken from their "9.5lb" flywheel.
