SR20 Downpipe on NA KA24DE for now?
daconkiftador
Car: '92 Coupe SE, '83 Rabbit GTi, '91 Golf GTi
I heard that the SR20 downpipe mates up to the stock KA downpipe location.. so I was wondering since I plan on going turbo, could I install the SR20 downpipe now to my stock KA exhaust manifold? That way Ive basically got a FULL exhaust minus the actual exhaust manifold itself? Ive got a 3" catback already installed.
This way when I finish piecing together my turbo kit, I can just get a turbo dumptube that mates to the SR downpipe. Let me know, maybe im compeletely off track =/
maybe the flanges are different since Im sure the stock exhaust manifold isnt 3", i dunno, any help would be awesome, thanks guys.
LINK:http://cgi.ebay.com/ebaymotors...QrdZ1
tiger
nope... It doesn't... I had my 3'' exhaust put on recently and I couldn't use my SR downipe.. the flanges are completely different.. this is for the KA24DE. So they cut the stock ka downpipe before the cat and welded a piece on so i would fit up to the rest of my exhaust.
240DRFT
what about if u use a s14 header?
tiger
well I have heard that works, I have never looked at an s14 KA's header before.. but my SR downpipe makes a triangular bolt pattern.. If the header has a triangular bolt pattern, it will probably work.
savethes13s
Car: toyota soarer
it will work if you are using a s14 header/elbow pipe. that is the combination that i am using on my girl's car.
240DRFT
ya, i have a s14 header on my ka and ive been looking at pics and it looks like it would fit.
daconkiftador
240DRFT.. s14 header on your s13?
240DRFT
ya, i put in a ka from a 96 and used the header.
daconkiftador
sweet u need to try it out and let me know.. LOL
tiger
For real... I just spend 123 dollars at the exhaust shop for them to make a custom downpipe to fit the rest of my 3in exhaust... not to mention it was 1/2 the stock downpipe = ****ty. So the exhaust elbow from a 14 will fit on a 13 then making it able to bolt up an sr exhaust.. yippie!?
240DRFT
tiger wrote:For real... I just spend 123 dollars at the exhaust shop for them to make a custom downpipe to fit the rest of my 3in exhaust... not to mention it was 1/2 the stock downpipe = ****ty. So the exhaust elbow from a 14 will fit on a 13 then making it able to bolt up an sr exhaust.. yippie!?
first...sr exhuast and ka exhuast are the same.
we were talking about using a s14 header and using a sr downpipe to connect the s14 header to the s13 cat.
AelSic
Car: 2006 Titan Crewcab
240DRFT, Tiger is from japan and probably has not spent much time with the KA. So, something so blatant to us is not necessarily known to her.
240DRFT
oh, didnt know that
tiger
[QUOTE=AelSic]240DRFT, Tiger is from japan and probably has not spent much time with the KA. So, something so blatant
Ael.. yea I have only spent about 9 months with the KA, so I don't know all the parts that you can interchange.. I see you have team hinga on your sig... were you ever in Oki? Damn, I miss rob! (fatdaddy)
SimpleEnigma
Car: 1992 240sx Coupe
The s14 header should bolt right up to an s13 motor just fine. it is the same motor and same chassis. The only changes from the s13 and s14 motors was the milder cams used in the s14, the change from external to internal coil distributor, the ECU tune, removal of the AIV on the S14 and the addition of a 2nd O2 sensor.
daconkiftador
what "elbow
savethes13s wrote:it will work if you are using a s14 header/elbow pipe. that is the combination that i am using on my girl's car.
What "elbow pipe"?
I thought it goes, Exhaust Manifold-Downpipe-Cat ?
So is it confirmed that the SR Downpipe with mate up directly with a stock KA Exhaust Manifold?
240DRFT
i think the answer is probably, since no one has actually tried. and note that the header has to be a s14 header.
Chezedik
Car: 1991 Nissan 240sx
Elbow pipe is how they refer to the little piece of pipe they use to hook up with the downpipe. It all uses the same 3 bolt flange.
daconkiftador
thanks for the clarification guys, i might have to try this out, found a hell of a deal on an s14 header, and Ive been wanting to get rid of my cat.
AelSic
Yea, from way back in the day. I've known Chris Kelley since high school. He has always been there for me when I needed him so I have to give them some props.
daconkiftador
so if Ive get a s14 exhaust manifold, do i need to make sure it has that "elbow pipe" with it, or is the "elbow pipe" just the downpipe, im kinda confused because I thought after the exhaust manifold itself, it just bolts to the downpipe without a lil "pipe" inbetween.
maybe a picture woud help, im we-todd-ed =/
AelSic
What it sounds like is that if you follow the exhaust manifold from the head down past the runners the first set of bolts/nuts you get to is where you attach the downpipe. Am I right or what?
savethes13s
Car: toyota soarer
the elbow pipe is used if your running a turbowhich comes from the exhaust side of the turbo and connect to the downpipe , but since you are running all motor right now it isnt needed
daconkiftador
ooh, from your original post I thought u meant you have to use both the header and "elbow pipe" not just one or the other for whichever application(na/fi). So on your gf's car is she running an SR downpipe from the stock s14 exhaust manifold, or is she KA-T?
daconkiftador
bump, so savethes13s can you confirm^ this?
dft24ds
Car: 95 nissan 240sx
A stock s14 exhaust manifold will bolt up to a sr downpipe. My buddy just did it on his s14
daconkiftador
dft24ds wrote:A stock s14 exhaust manifold will bolt up to a sr downpipe. My buddy just did it on his s14
Thank you... I think this thread is now confirmed an' ova.. lol.
